I've also noticed a noise from the engine compartment lately, although i suspect it may not be related to the overheating. It sounds like rattling from a heatshield or bad bearings from something. It doesn't sound like it's coming from the water pump, although it's hard to tell.
2000 Honda Civic Overheating at Idle
Recently my 2000 Civic (200,000 miles) has been running hot when the engine is idle. It runs at normal temps when moving AND also runs at normal temps while parked if I rev up the RPMs a little bit. Once hot, I can watch the temperature drop almost instantly when I rev up the engine a thousand RPMs or so.
Apr 24, 2007 at 1:33 AM
[quote:0480735576="c0ba1t"]Recently my 2000 Civic (200,000 miles) has been running hot when the engine is idle. It runs at normal temps when moving AND also runs at normal temps while parked if I rev up the RPMs a little bit. Once hot, I can watch the temperature drop almost instantly when I rev up the engine a thousand RPMs or so.
I've also noticed a noise from the engine compartment lately, although i suspect it may not be related to the overheating. It sounds like rattling from a heatshield or bad bearings from something. It doesn't sound like it's coming from the water pump, although it's hard to tell.[/quote:0480735576]
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Apr 24, 2007 at 10:13 AM
Suggested Repair
Start by replacing the thermostat. If overheating continues, have a block test and cooling-system pressure test done to check for combustion gases or a head-gasket leak; do not pressure-test if a head-gasket leak is already suspected. Also check the radiator cap, radiator for clogging, air in the system, radiator fan and fan clutch, collapsed hoses, and the water pump.
Conversation Summary
A 2000 Honda Civic with about 200,000 miles runs hot at idle but returns to normal temperature when moving or when the engine is revved slightly. A rattling noise was also noted but may be unrelated. The expert recommended replacing the thermostat and, if needed, testing for combustion leakage and checking the radiator, cap, fans, hoses, air locks, and water pump.
