1993 Honda Civic Overheats at Idle
VARK
I have a 1993 Civic EX Automatic with 195,000.
The problem is that the Temp rises when the car is in idle and the A/C is on, the condenser fan and radiator fan are good, the relays for the fans and the compressor relay are also good. As long as I am at highway speeds it is fine due to the air flow. The Compressor Clutch seems to stay engaged as I cannot hear it cycle in and out, it only heats up when the clutch does not cycle. I do not know if the Clutch is bad, or the pressure switch, or something else, I prefer to buy the parts myself online and either take it locally or do it myself. I have not checked the R12 pressure.
Aug 9, 2007 at 7:29 AM
BRUCE HUNT
  • 3,754 POSTS
I assume that it is the temp of the engine that rises. I believe that you have a leak in the cooling system. Not A/C. You might have the cooling system pressure checked.
Aug 9, 2007 at 9:26 AM
Suggested Repair
Have the cooling system pressure-tested for a leak. The expert attributes idle overheating to the cooling system rather than the A/C.
Conversation Summary
A 1993 Honda Civic EX overheats at idle with the A/C on but stays normal at highway speeds. The owner reports both fans and related relays are good, the compressor clutch stays engaged, and refrigerant pressure has not been checked. The expert says the rising engine temperature points to a cooling-system leak, not an A/C fault, and recommends a cooling-system pressure test.
