Honda Civic Check Engine Light No Code
KRISTA
I then bought the car.... Engine Light comes on three weeks later while gearing up from a stop. The car this time jerks violently in 1st & 2nd, (like with someone who can't drive standard). Car fine in neutral- pull over, turn off car and then back on ... engine light still on but no running problems.
Check for codes - No code! What is going on?
Apr 7, 2007 at 10:59 AM
JOUGH626
  • 55 POSTS
I had a similar problem. Everything was fine, engine wouldn't run and it without the engine running, the check engine light would not come on. My manual said after 10 seconds of cranking with no start, the CEL would come on alerting you to a problem. the CEL never came on. My manual said, not in so many words, that if everything else is ok and you don't get a CEL or a code, the engine computer is faulty.
My suggestion is to find a known working engine computer and swap it out. Good luck.
May 19, 2021 at 7:22 AM
BRUCE HUNT
  • 3,754 POSTS
Clear the computer again. Check the tranny fluid for level and color. Then I ask where are you getting the codes read? Have you considered another pull at the codes with a different system?
KRISTA
Thanks for the tip. I will check the tranny fluid.
I will most likely have it looked at by the $mechanics$ for the sake of their computer technology. I had checked for the codes via the procedure recommended in the codes book, (insert connector piece or paper clip into 2 wire connector under the dash passenger side.) After several attempts with no codes flashing, what does one do but reset and hope it a) never happens again b) next time it happens there's a code!
BRUCE HUNT
  • 3,754 POSTS
Precisely! Is it running good though?
KRISTA
Yes, it runs just like a new car. :)
Suggested Repair
Clear the computer, check transmission fluid level and color, and reread codes with a different scanner. If no codes appear and the problem returns, test or swap in a known-good engine computer.
Conversation Summary
A Honda Civic owner reported a check engine light with violent jerking in 1st and 2nd gear after pulling away, then normal running after a restart and no codes from the under-dash flash procedure. Experts suggested clearing the computer, checking transmission fluid, trying another code reader, and possibly replacing a faulty engine computer. The owner later said the car was running normally.
