Honda Civic Check Engine Light
i'm quite frustrated with this whole check engine light. i've spent over $150 on this problem, only to find that i'm not covered under their extended waranty (warranty extended to 14 yrs after the date vehicle was first sold/or 150,000 miles whichever comes first).
check into it asap. don't wait for some recall or extended warranty - they're likely to inform you well after you're elligible for coverage.
lillybug
Now that said, let me add that some codes are intermittent and will clear themselves. Eventually they will get bad enough to trip the light and stay on. Don't keep going to Honda. You have to pick and choose what you want them to repair for you.
If fact, come back to this site and ask for a recommendation whether a needed repair is a Honda problem or if another mechanic could handle it. We will try to give you a hand with that.
Suggested Repair
Have the check engine light scanned for free at a parts store, or use an inexpensive code reader, then look up the code before paying for more dealer diagnostics. Also check that the fuel cap is tight and its gasket is intact. Intermittent codes may clear themselves until the fault becomes consistent.
Conversation Summary
The owner of a Honda Civic reports an intermittent check engine light while the car otherwise runs normally and does not overheat. A dealer charged for one diagnostic and proposed additional paid tests without estimating how many would be needed. Replies suggested a free parts-store scan, a loose or damaged fuel cap, and checking a Honda emissions warranty extension that applied to some mid-1990s models. The expert advised reading the code with a free or low-cost scanner, looking it up, and avoiding repeated dealer diagnostics until the fault is identified.
