You could have had a brake that was dragging. It should have been extra hot and unless both were dragging it should have pulled to that side as well. Possible but there might be other answers.
Obviously, you need the work done one the brakes. I would see what the result is afterwards. If you notice the problem again, feel the rotor and do so with care as it might be very hot. Once you eliminate the brakes you are in to the engine looking for problems. This could be related to plug wires to O2 sensors.
SPONSORED LINKS
Tuesday, August 7th, 2007 AT 1:07 PM
