2001 Honda Civic A/C and Brake Light
LUISITILLO
HONDA CIVIC 2001, MILEAGE 65000, 1.7. THE PROBLEM WITH THE A/C IS THAT THE INSIDE FAN TURNS ON BUT THE OUTSIDERS LIKE THE COMPRESSOR, THE RADIATOR FAN AND THE CONDENSER DON'T. I'VE CHECKED EVERY BASICS BUT I DIDN'T FIND ANYTHING WRONG AND WITH THE BRAKE SYSTEM IS THAT THE SIGN BREAK STAYS ON IN THE CLUSTER SYSTEM, I'VE CHECKED FOR LEAKAGES, THE OIL AND THE PARKING BRAKE BUT IT'S FINE. ANY SUGGESTION OF WHAT COULD IT BE?
THANKS
Sep 12, 2007 at 2:29 PM
BRUCE HUNT
  • 3,754 POSTS
I would check under the hood for relays and fuses on the components. The fans at the radiator can be hooked to a 12 volt source to be tested but I suspect they are fine. This could be a temp sensor that has failed.
The BRAKE system might just be telling you it has a bad bulb at the brake lights or the sensor on the hand brake could be bad or stuck.
Sep 13, 2007 at 1:46 AM
Suggested Repair
Check under-hood relays and fuses for the A/C compressor and cooling fans. The fans can be tested with a 12-volt source, but a failed temperature sensor is a likely cause. For the brake warning light, check for a bad brake-light bulb or a stuck or failed parking-brake switch.
Conversation Summary
Owner of a 2001 Honda Civic reports the cabin blower runs but the A/C compressor, radiator fan, and condenser fan do not. The brake warning light also stays on after checking fluid, leaks, and the parking brake. Expert advises checking relays and fuses, notes the fans are likely fine if they run on 12 volts, and suspects a failed temperature sensor. The brake light may indicate a bad brake-light bulb or a bad or stuck hand-brake sensor.
