1995 Honda Civic Distributor Order
MGAN9311
I have a 95 Honda Civic Ex 1.6 230,000 miles and I recently gave myself a tune up and forgot to check the order of the wires to the distributor cap. My repair manual says 1-4, in that order starting clockwise from the point of the distributor spring. Then I found, in another chapter, the manual stated from 1-4 clockwise starting for the letter or number on the cap...I tried both ways and my car still wouldn't start. I literally had to play around with it until I got it right and my car started. Can someone tell me what the real order is? Or does it vary? Just for future reference.
Also, my exhaust manifold is cracked. Would this cause lower gas mileage and where can I get the part for a reasonable price? Thanks.
Apr 3, 2006 at 2:58 AM
LOSONE
  • 1,616 POSTS
The firing order is 1342.
#1 cylinder on the engine is at the front, next is #2 and so on.
#1 on the distributor cap should be at the nine o'clock position, when looking down at the top of the cap. The direction of rotation is clockwise
You don't want to know how much a dealer price is. Go to a salvage yard and get a $50.00 one. Get Honda factory gaskets--you'll save yur self a lot of time.
Apr 3, 2006 at 6:21 AM
MGAN9311
Thanks. I appreciate the info. How long do you think it would take to replace the manifold?
Apr 3, 2006 at 2:31 PM
LOSONE
  • 1,616 POSTS
If no bolts are frozen about 2 hours--if bolts are broken then /???
Apr 4, 2006 at 1:03 AM
MGAN9311
Thanks. Ya, yet's hope those bolts aren't seized like my O2 sensor was! It had to be drilled out and re-threaded about 5 years ago. I am wondering if this caused the crack or at least weakened it enough that the crack occured during freezing temperatures. You can tell its been there a while. The edges of the crack look like they are a bit rusted.
Apr 4, 2006 at 1:39 AM
BENZ_GUY
  • 28 POSTS
If you want to get back to the basics of making sure you have everything correct follow these instructions.
A few ways to do this. With both ways, make a point to watch which direction the bottom "crankshaft pulley" is rotating when the starter in engaged.
1) Install compression tester in Cyl #1 (usually the one closest the pulley on 4cyl engines) and have someone tap the key until you see the pressure starting to come up. This will put you on the compression stroke of #1 cyl. Put a socket on the crankshaft bolt and continue rotating the engine (in the same rotation you witnessed earlier) until the TDC mark "0" lines up with the timing pointer on the block.
Then pop open the distributor cap. You should be pointing toward plug wire #1. If not, pull all the plug wires out of the cap and install plug wire #1 right where the distributor is pointing to. Then follow losone’s information on the rest of the firing order based upon the rotation of the rotor inside the dist. cap.
2nd way to do it (if you don't have a compression tester)
Pop off the valve cover and put a socket on the crankshaft bolt and continue rotating the engine (in the normal rotation) until you see the intake valve(s) open and close (easy way to tell the difference between intake and exhaust valves is to see which side is connected to the muffler and which side is connected to the intake, wahh laa exhaust side=exhaust valve / intake side = intake valve - it's really easy to tell)
Now once you see the intake valve open and close keep turning the crank pulley until the TDC mark "0" lines up with the timing pointer on the block. You should now be on "top dead Center" on the compression stroke.
Hope this helps
Apr 4, 2006 at 3:45 PM
Suggested Repair
Set the firing order to 1-3-4-2, with cylinder 1 at the front of the engine and distributor terminal 1 at the nine o'clock position when viewed from above; rotor rotation is clockwise. Confirm cylinder 1 is at TDC on the compression stroke before installing the plug wires. For the cracked exhaust manifold, use a salvage-yard manifold with Honda factory gaskets; replacement takes about two hours if the bolts are not seized or broken.
Conversation Summary
The owner of a 1995 Honda Civic EX 1.6 had mixed up the distributor plug-wire order after a tune-up and also reported a cracked exhaust manifold. An expert stated the firing order is 1-3-4-2, with cylinder 1 at the front and terminal 1 at nine o'clock, rotating clockwise. Another reply explained how to find TDC on the compression stroke and place wire 1 where the rotor points. For the manifold, the expert recommended a roughly $50 salvage part with Honda gaskets and estimated about two hours if bolts are not frozen or broken. Lower fuel mileage from the crack was not directly confirmed.
