2005 Honda Civic Excessive Noise
48,000 MILES • 4 CYL • FWD • AUTOMATIC
STONEGATOR
I've noticed a pronounced increase in noise when I exceed 45-50 mph. Is really excessive around 60+ mph. I thought it was in the engine, so I put the car in neutral and revved the rpms to above 3,000 but did not replicate the sound. Noise only is audible when driving fast. Something in the wheels/brake/rotor aparatus seems to be wearing down.
Just had oil change and car's maintenence checked six weeks ago and Honda mechanic said brakes were fine.
Aug 18, 2010 at 3:00 AM
KHLOW2008
  • 41,812 POSTS
Hi stonegator,
How does the noise sound like?
If it is a growling type noise and increases with road speed only, then it most probably would be a bad wheel bearing.
Aug 19, 2010 at 7:24 AM
STONEGATOR
Yes, the noise is a growling sound and it does amplify with an increase in speed.
Aug 19, 2010 at 7:31 AM
KHLOW2008
  • 41,812 POSTS
Find a road with a gentle curve. While driving note if the noise increases and decreases when making turns. If yes, at least one of the wheel bearings is bad.
Aug 19, 2010 at 7:41 AM
STONEGATOR
Okay. Thanks. Any idea if it's a big job or cost?
Aug 19, 2010 at 7:49 AM
KHLOW2008
  • 41,812 POSTS
Book time for replacing a front wheel bearing is 1.3 hour.
The bearing is listed at $89.23.
Labor cost and parts prices varies region to region so you should check out local conditions for the correct rpice.
Aug 19, 2010 at 11:16 PM
STONEGATOR
Thank you!
Aug 20, 2010 at 12:00 AM
