2004 Honda Civic OBD II P2000 and CEL on Civic Hybrid
2004 HONDA CIVIC
103,000 MILES • 4 CYL • 2WD • AUTOMATIC
SOYTREJO
Car running great, but getting persistent CEL that has reset on own a couple of times. I have found that this code can mean "NOx Trap Efficiency Below Threshold (Bank1)" which seems to be associated with O2 sensor in some posts but then in others seems to be associated with bad catalytic converter and I have even found it associated with the rechargeable battery???? Help! Thanks in advance.
Jan 11, 2009 at 12:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
This code usually indicates a faulty oxygen sensor(s). However, in some instances it can also be used for a faulty catalytic converter as well, since the O2 sensors are located on the exhaust system along with the cat. converter(s). You should check out the following link to test your oxygen sensors before replacing anything.
https://www.2carpros.com/how_to/how_to_test_oxygen_sensor.htm
If the tests come out good then faulty cat. converter is the issue.
Hope this helps..
Thanks for using 2carpros.com!
May 19, 2021 at 6:38 AM
