Hi jst3000,
Yep, the ECM is very relaible and seldom requires replacement, unless some short circuit occurs.
The OBD II that you used might not be compatible or not properly attached or power to the OBD II connector is not available.
Recheck the thermostat ground by loosening and retightening again.
Green key light = anti theft system, check for loose ground at control unit, it might cause the engine to stall.
SPONSORED LINKS
Tuesday, June 10th, 2008 AT 12:33 PM
