2002 Honda Civic engine stops while driving
100 MILES • 4 CYL • 2WD • MANUAL
DRSAMIYAZIED
while driving engine stops,battery lamp get red then directly all others.I noticed this when weather is very hot althogh water from radiatier does not decrease and also temperature reaches maximum to half reading and never exceed, but it is within seconds I can drive again without delay and the problem reoccur again within 20 Kilometers.
I never notice that at night time.
Thanks
May 15, 2010 at 10:44 PM
F4I_GUY
  • 3,302 POSTS
If the temperature is reaching maximum you are overheating the vehicle. Please do not drive the vehicle like this. As to what your problem may be, headgaskets are common on your vehicle. You may also find that it may be as simple as a cooling fan relay. However, you need to get it checked out a.s.a.p.
May 16, 2010 at 11:31 PM
DRSAMIYAZIED
My honda Civic does not overheat, it reaches always to half reading of temperature and never stop unless in longdistance more than 300 Kilometers and only when it is very hot weather.Even if i do not use A.C
the same problem occurs,Everything is working ok,as fans, air condition ,radiator engine oil,water as same level in radiator(very little decrease).
May 17, 2010 at 7:47 AM
