2002 Honda Civic
PUKIMAN1111
  • 2002 HONDA CIVIC
  • 4 CYL
  • FWD
  • 150,000 MILES
Inside of car smells bad I check water level in radiator is
low.
check for leaks and under car there is a drain hose
were water in rust color is coming out
what is the hose for a heater drain?
hose is located front mid section under car. Were heater is above it. Just a hose sticking out not attache to nothing. Looks like a drain hose.
but lot of water is coming out of it. And I think thats were the smell is coming from.
what do you think that is. Crack core on car heater?
Thanks
RH
Tuesday, March 17th, 2009 AT 6:16 PM
KHLOW2008
  • 41,814 POSTS
Hi RH,
That should be the AC evaporator drain hose, slightly off centre of vehicle. If water is present in cabin due to clogging of hoses or leaking, it would emit a foul smell.
There are no other hoses for drainage from cabin.
Thursday, March 19th, 2009 AT 9:13 AM
PUKIMAN1111
Thank you
Thursday, March 19th, 2009 AT 6:03 PM
