2002 Honda Civic blower work but no heat
160,600 MILES • 4 CYL • FWD • AUTOMATIC
DBARSHAW
The car heats up to normal temps. I have to adjust the temp control dial hot to cold back and forth and it will heat up. I have checked all fluid levels and they seem fine. Is the thermostat sticking shut? A heat sensor going bad?
Thanks Darren
Feb 23, 2010 at 6:00 AM
F4I_GUY
  • 3,302 POSTS
First you have to ensure that the heat controls inside the dash are functioning properly. If the heat control is not moving the heat door inside the dash to 'heat' then obviously there will be no heat inside the vehicle.
If the controls are fine, then check your heater core, thermostat and coolant level.
Feb 23, 2010 at 12:27 PM
