2002 Honda Civic
PLOTRU
  • 2002 HONDA CIVIC
Electrical problem
2002 Honda Civic 4 cyl Two Wheel Drive Automatic
how do you turn maintenance light off
Wednesday, March 11th, 2009 AT 10:08 AM
BMRFIXIT
  • 19,053 POSTS
1. To reset the MAINT REQ'D indicator light, turn ignition switch to OFF position. Press and hold the SELECT/RESET button. While still holding button, turn ignition switch to ON position, with engine off. Hold SELECT/RESET button for about 10 seconds until indicator resets.
2. If MAINT REQ'D reminder light does not reset, ensure headlights, parking lights, or both are turned off when resetting reminder light. The MAINT REQ'D indicator can not be reset if any of these lights are on. If vehicle is equipped with daytime running lights and lights come on when ignition switch is turned to ON (II) position, daytime running lights must be disabled before indicator light can be reset.
Thursday, March 12th, 2009 AT 6:20 AM
