HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Overheat
2001 Honda Civic Over heating
JUNEYTOEZ
MEMBER
2001 HONDA CIVIC
4 CYL
FWD
AUTOMATIC
35,000 MILES
What is the cause of my car to overheat? However, I saw coolant dripped from under radiator.
Monday, January 5th, 2009 AT 5:50 PM
KHLOW2008
MECHANIC
Hi juneytoez,
There are a few reasons why overheating occurs.
1. Radiator fans not working.
2. Lack of coolant.
3. Faulty thermostat
4. Faulty water pump.
5. Clogged radiator.
Since coolant is leaking from radiator, you need to check where it is leaking from and rectify it.
SPONSORED LINKS
Sunday, January 11th, 2009 AT 9:14 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Overheating While On Freeway
I Have A 01 Civic Ex That Has Had Overheating Issues For A While Now. Here Is A List Of The Work We Have Done So Far. -replaced...
Asked by
crotalus84
1 IMAGE
2001
HONDA CIVIC
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
2001 Honda Civic Car Over Heating
My Car Overheats After Prolonged Driving. The Coolant Reservoir Tends To Build Up Too Much Fluid And Doesnt Drain.
Asked by
jensenbe
2001
HONDA CIVIC
Overheating
My Car Has Been Using A Little Water/antifreeze Every Day, Not Much. Other Day It Overheated Due To Bottom Hose Coming Loose On Radiator....
Asked by
60janet
2001
HONDA CIVIC
2001 Honda Civic Overheating
I Have A 2001 Honda Civic That Is Having Some Overheating Issues. Basically, When The Car Idles, The Engine Shudders At Low Rpm's And...
Asked by
bdubs
2001
HONDA CIVIC
2001 Honda Civic Random Overheating
My Honda Civic Has Recently Overheated On A Couple Of Occasions. It Is Random And So Therefore Has Me A Bit Confused. It Has Done This Two...
Asked by
neilfgow
2001
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
