HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Overheat
SPONSORED LINKS
2001 Honda Civic Car over heating
JENSENBE
MEMBER
2001 HONDA CIVIC
4 CYL
FWD
AUTOMATIC
118,000 MILES
My car overheats after prolonged driving. The coolant reservoir tends to build up too much fluid and doesnt drain.
Wednesday, May 19th, 2010 AT 9:53 AM
BLUELIGHTNIN6
MECHANIC
Make sure cooling fans are coming on. Also remove and test thermostat.
SPONSORED LINKS
Wednesday, May 19th, 2010 AT 12:43 PM
JENSENBE
MEMBER
1 POST
Both fans are comming on, new thermostat. New radiator, hoses, and coolant reservoir.
Wednesday, May 19th, 2010 AT 12:48 PM
BLUELIGHTNIN6
MECHANIC
Did you have coolant system flushed during radiator replacment? Could have a partial clog in system somewhere causing overheating.
Wednesday, May 19th, 2010 AT 12:49 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Overheating While On Freeway
I Have A 01 Civic Ex That Has Had Overheating Issues For A While Now. Here Is A List Of The Work We Have Done So Far. -replaced...
Asked by
crotalus84
1 IMAGE
2001
HONDA CIVIC
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Overheating
My Car Has Been Using A Little Water/antifreeze Every Day, Not Much. Other Day It Overheated Due To Bottom Hose Coming Loose On Radiator....
Asked by
60janet
2001
HONDA CIVIC
2001 Honda Civic Overheating
I Have A 2001 Honda Civic That Is Having Some Overheating Issues. Basically, When The Car Idles, The Engine Shudders At Low Rpm's And...
Asked by
bdubs
2001
HONDA CIVIC
2001 Honda Civic Random Overheating
My Honda Civic Has Recently Overheated On A Couple Of Occasions. It Is Random And So Therefore Has Me A Bit Confused. It Has Done This Two...
Asked by
neilfgow
2001
HONDA CIVIC
What Can Cause My 2001 Honda To Heat Us So Bad That The Exhaust Manufold Gets Cherry Red. I Have Checked The Exhaust System For A Blockage...
Asked by
Andy falcon
2001
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
