No an o2 could not cause this.
Have you had the catalytic convertor flow tested? Or have you have a back-pressure test done (this would be the better diagnostic test to be used to solved this problem).
You may use an actual exhaust pressure gauge, or a vacuum gauge on the intake manifold.
SPONSORED LINKS
Friday, April 24th, 2009 AT 5:32 PM
