Check your clutch fluid level located on the driver side firewall. If it's low, check your master cylinder and slave cylinder for leaks. You may also have a leaking line or flex hose.
SPONSORED LINKS
Monday, March 15th, 2010 AT 5:13 PM
JAY24
MEMBER
Checked the fluid level. It's ok. Checked for leaks but found none. Can it be the Clutch Release Bearing? Anyways, I think I need to get professional help on this. Thanks so much for the info!
