2001 Honda Civic acceleration or fuel problems?
SDISTASIO
  • 2001 HONDA CIVIC
Engine Performance problem
2001 Honda Civic 4 cyl Front Wheel Drive 124000 miles
This problem just started on Sunday, while I'm driving sometimes if I attempt to push the gas to go faster it will not let me the car won't accelerate but, it still sounds like it is but the speed starts to drop. And my engine sound bad almost like there is a tick or something now it's very loud and as I said this all started on Sunday late afternoon as I was traveling on the interstate about an hour to two hour drive.
Please help!
Thursday, April 29th, 2010 AT 4:41 PM
If the transmission is not slipping, check and test below components
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, April 29th, 2010 AT 4:55 PM
