Hooked up to monitor to retrieve trouble codes set by on board computer. P1487 code set for EVAP Emission Vent fault. Small leak in EVAP system. Smoke Test EVAP system to diagnose faulty part. Test FTP sensor, Canister, VSV, and Vacume holding valve. Clear codes after replacing parts. Replaced cannister shut valve. Check Engine Light on again so test and replace EVAP bypass solenoid and two way valve assembly. Code on again. Pulled gas tank and checked seals on tank and gas fill. Code P1487 again. Replaced computer. Code P1487 again. Any assistance would be greatly appreciated.
SPONSORED LINKS
Monday, March 29th, 2010 AT 9:22 AM
