2000 Honda Civic broken head gasket
FLO_FLOCHE
  • 2000 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 10,000 MILES
How do you fix a broken head gasket and what other parts in the car are affected by it over heating like this?
Friday, November 14th, 2008 AT 3:18 PM
IMPALASS
  • 3,112 POSTS
Hello
For a blown head gasket the head must be removed. While off with the number of miles you have you need to do a valve job. The head will have to be resurfaced anyway (due to the heat) so the valve job is necessary.
The cooling system should be flushed and I would change the thermostat.
You will need to change the oil and filter.
If you want the information on head removal, I will need to know the specifics on your vehicle such as is it a CX, DX, EX or what model, coupe, sedan etc and the specific engine liter size and 8th digit of your vin.
Saturday, November 15th, 2008 AT 12:26 AM
