Transmission won't engage
WRECKER1
  • 7 POSTS
Actually, I have one more, it started whinding real bad like maybe the starter or the flywheel or maybee even the dustributer was dragging or rubbing like?
Monday, July 6th, 2020 AT 4:47 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Where is the noise coming from?
A bearing inside the distributor is known to fail quite commonly and that ould be the cause if the noise is from there.
WRECKER1
  • 7 POSTS
Sounds more like as if the starter hasn't pulled back ll the way, sort of, like a corner of a playing card in the spokes, now what I meen?
WRECKER1
  • 7 POSTS
But a high, whinnig pitch
KHLOW2008
  • 41,814 POSTS
Get a rubber hose and place it near to where it is coming from to locate the exact source. Of course you need to place one end to one of your ear. Lol
LEETOZ
Hello Khlow, I am having this same issue on my 2003 Honda Accord. It seems to drive and shift ok when "cold" but as soon as it gets hot enough or I drive for about 20 mins, it stops engaging. Even when driving it seems like it just pops out of gear and I can just hear the engine roaring, but no movement. Could this be the same issue?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Yes, this could be. Can I ask if you have run the codes? Here are two guides to help us get started:
and
CARLOS MARTINEZ2
I'm having the Same problem wit a new/used transmission the old one stopped working and when put it in park it would make a grinding noise so I put in a used transmission with 130k miles but now it will move when it's cold and when it gets hot it won't move and rev out and speedometer doesn't work. When I let it sit for 2-6 min it works. But shifting hard any idea please help I've put in to much money in it to just give up. Its a 1994 Dx coupe 2door 1.5l
KEN L
  • 48,363 POSTS
It sounds like one of the CV axles is not in all the way. Can you please shoot a quick video with your phone so we can hear the noise? That would be great. You can upload it here with your response. That way I can hear the problem.
