You are obviously loosing coolant from the cooling system. Any water or coolant in the oil?
I suggest a compression check. Determine if the cylinder compression is weak and check to see if the compression is consistant in all cylinders.
After that it is time to get down and dirty. I would pull off the head, have it looked at and checked for cracks and warpage. I would look at the head gasket to see if it is bad and note what the top of the pistons look like. Are they oilly, does it appear that the oil is coming from the rings or dripping down through the head. The engine is not good. Head gasket and head check could fix it or improve it. But if the rings are bad it is engine rebuild or replacement time.
Jun 1, 2020 at 6:29 AM
(Merged)
