1999 Honda Civic Idle valve problem
EMIDGETT
Engine Performance problem
1999 Honda Civic Two Wheel Drive Manual
Is cleaning the idle valve a "backyard" mechanic issue or does a real mechaninc need to do it? In other words, how involved is it to get to the idle valve and or does it need to be removed for cleaning or what?
Apr 2, 2009 at 3:09 AM
F4I_GUY
  • 3,302 POSTS
Usually if it's causing an idling issue I like to remove the valve completely so i can fill it up with cleaner and let it sit for 2 minutes, then blow out the cleaner with compressed air and repeat until it's clean.
From a servicing aspect you can access the idle passage with just the intake tube off and you can clean it that way.
Apr 2, 2009 at 11:31 AM
