First thign to do is check for vaccum leaks by idling the vehicle and spraying all vaccum lines and gaskets wirth car cleaner, if idle changes you have found a leak.
Also clean out the throttle body and EGR valve/ports.
Replace the pcv valve and check out the IAC module.
SPONSORED LINKS
Monday, February 4th, 2008 AT 7:24 PM
