i took it to the garage and they could not find any obvious problems, so the put the diagnostics upto to and come up with trouble code 64, the mechanic says the civic codes only go upto 40, so he took them as being, 6 & 4, one being for a temp sensor and one for the map sensor (very expensive). So he changed the temp sensor, it was fine for a little while but the problem is still there, it hesitates at low rev's and sometimes makes a dodgy cranky noise when it's cutting out.
any idea what I could be, the mechanic goes it could be down to the map sensor now (but it's  £180 and im only going to get that if it's definately is the map sesnor) I have looked on forums and peeple are saying it could be the fuel fillter, inlet manifold bulit up with carbon deposits, distributor or even an altenator surging from high to low.
pls advise as this is getting very frsutarting
SPONSORED LINKS
Wednesday, November 25th, 2009 AT 3:25 PM
