With ignition switch turned on, dash indicators showing and no power to distributor would mean a break in the wiring circuit.
Now would be the difficult part. Locating the source of the break.
Nov 2, 2020 at 5:28 AM
(Merged)
BLACKOP555
✓Experienced Mechanic
sounds like yoru not getting an ignition pulse. possibly bad icm or crank sensor but what you should do first is to put a noid light in between th power and ground on coil and crank. does it flash?
(Merged)
AUSTINMARTIN
MEMBER
I got the black and yellow wire to have power now. but it wont turn over now.
(Merged)
KHLOW2008
How did you do that?
Now you need to test for battery voltage to the starter solenoid.
High possibility you have a bad ignition switch.
(Merged)
AUSTINMARTIN
MEMBER
today when i went to test the black and yellow wire it had power but then it wouldnt crank.
(Merged)
KHLOW2008
Did you test the starter solenoid wire for battery voltage at cranking position?
(Merged)
AUSTINMARTIN
MEMBER
No I did not.
(Merged)
KHLOW2008
If you don't want to do any testings, how do you expect us to help you?
(Merged)
AUSTINMARTIN
MEMBER
The little wire to the starter solenoid does not have power
(Merged)
AUSTINMARTIN
MEMBER
when you try and crank the car
(Merged)
KHLOW2008
The same wire is powered from the ignition switch. Try same procedure and test at ignition side for the same wire. If voltage is not available, you have a faulty ignition switch.
