1998 Honda Civic Termostat taken out still over heating
BOCIVIC
  • 1998 HONDA CIVIC
  • 4 CYL
  • FWD
  • 13,000 MILES
Honda Civic 98 EX
Took out thermostat two weeks ago.
Still overheating on highway.
When slowing down the temp starts to fall, but still overheating past halfway. When pressed on the gas the car heats up even more.
I checked the coolant and refilled as needed a week ago.
Still over heating, while coolant is full.
HELP PLEASE.
Wednesday, May 5th, 2010 AT 4:09 PM
Check the radiator if its clogged-up, water pump functioning if both ok -try bleeding the cooling system don't work get it block and pressure tested to rule out a blown headgasket cracked head and block and an intake leak
Wednesday, May 5th, 2010 AT 4:46 PM
BOCIVIC
I found out that my car starts to cool down when I have the setting on heat. Why?
Thursday, May 6th, 2010 AT 4:13 PM
Bcuz you are removing heat from the heater core which coolant goes thru it
Friday, May 7th, 2010 AT 3:16 PM
