car overheats every now and then.
180,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
L2WO4OUR
  • 20 POSTS
so ive replaced the radiator cap, thermostat, and the water pump and the car still overheats. the problem is it overheats every now and then its not constant. all i gotta do is add more coolant every time it does that. and when it overheats when im on idle as soon as i start driving the temperature gauge goes down. Any ideas why the coolant spills out and it overheats every now and then. I suspect its a clogged radiator but i did a flush on it. Another thing with the car on and radiator cap off are you suppose to see the coolant flow or just sit there.
Mar 17, 2014 at 3:21 AM
SATURNTECH9
  • 30,868 POSTS
Sounds like the radiator fan isnt working correctly if it cools down once you start driving.
Mar 17, 2014 at 3:27 AM
L2WO4OUR
  • 20 POSTS
How do I test the fan or what
Mar 17, 2014 at 6:42 AM
SATURNTECH9
  • 30,868 POSTS
Does the radiator fan ever come on or is it on when its running hot?
Mar 17, 2014 at 11:43 AM
SATURNTECH9
  • 30,868 POSTS
Need to know before we go chasing something thats not the problem.
Mar 17, 2014 at 11:46 AM
