1998 Honda Civic Ignition
BATTLESHIPBAGELS
  • 1998 HONDA CIVIC
Electrical problem
1998 Honda Civic 4 cyl Automatic 80,000 miles
Whenever my car has about 4 gallons of gas left in the tank, the ignition takes longer to catch. If the tank is full it's fine, but I don't know if this is a characteristic for this car or not, or if it could be a minor problem that potentially could get much worse. As far as I know, the refuel light does not come on (if it works, I bought it third hand and although it was from a dealership there are no records of major work being done to it) and I would like to know how to fix it or how much it would cost to fix. (Since it does take longer for the ignition to catch when the gas is semi low, I'm in the habit of refueling it as soon as it begins to take its time starting-it makes me nervous-, so I'm not sure if the refuel light works.)
Tuesday, October 6th, 2009 AT 5:25 PM
F4I_GUY
  • 3,302 POSTS
Very common. The way the fuel system was designed, it just takes longer to build up fuel pressure in the lines.
When you turn the vehicle on. Leave the car on the RUNII position until the check engine light or SRS light turn off. Then crank the vehicle. It'll start up fine.
Wednesday, October 7th, 2009 AT 7:13 PM
BATTLESHIPBAGELS
Thank you :) at what point does the refuel light come on? I know for most cars it's when there's a little more than 1 gallon left but after reading the manual it doesn't say.
This is my first car so I'm still learning the details about it.
Thursday, October 8th, 2009 AT 12:08 PM
