1997 Honda Civic Transmission jerking and D light Blinking
230,000 MILES • 4 CYL • FWD • MANUAL
HORTONL
I have recently replaced my motor on my 1997 Honda Civic. Now, the car jerks when in Drive and I have to drive the car in the lowest gear possible. The lights blink on the dash. I have had it on the analyzer and it indicated that I needed a transmission censor and still no luck.
Any suggestions.
Apr 30, 2009 at 11:49 PM
TED-E-DEE
  • 109 POSTS
The car needs to be hooked up to a scanner. It sounds like you may have done that ? Is that how you found out about sensor ? When a scanner gives a code & says a component is'nt working, that does not mean the component is bad. That is just the begining of the diog. It needs to be diognosed to find out "Why" the component is'nt working. It could be a number of things causing it not to operate properly. Ck. fluid level ? There have been situations where the Trans. was drained thinking it was the motor oil. Good Luck !
May 1, 2009 at 10:33 AM
