1995 Honda Civic Cost to replace transmission
170,000 MILES • 4 CYL • 2WD • MANUAL
THESPOON24
Looking into buying a car - 1995 Honda Civic DX that needs transmission work. Just to be on the safe side, how much would it cost to replace the transmission completely? Also do you know what a common problem might be and how much it would cost to fix? Car is selling for $900 - I think this might be a good deal...Thanks!
Aug 28, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
should just be $300 to $400 in labor fees to remove and replace the tranny plus the cost of the replacement tranny. the tranny could just need a sensor replaced though so would be good to check out the old tranny before replacing it.
Aug 28, 2010 at 1:15 PM
THESPOON24
Thank you! That was very fast and very helpful. Would you happen to know a ballpark range for the tranny in this instance?
Aug 28, 2010 at 1:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
not sure of your exact details (2 door, 4 door 1.5L etc...) but i did a quick search at www.car-parts.com and there seem to be a lot of used manual trannys for the 1995 civic at around $250 w/ warranty.
Aug 28, 2010 at 1:21 PM
THESPOON24
Awesome! Thanks.
Aug 28, 2010 at 1:22 PM
