1997 Honda Civic Replacing the CV Joint Boot
98,000 MILES • 4 CYL • FWD • MANUAL
JEOKU
I am trying to replace my CV joint boots. I already removed the clamp on the boots and was able to slide them away from the cv joint. My problem is that I do not know how to seperate the cv joint from the axle. How do I get this off? Do I just need to put it in a vice and hammer at it?
Also... since Im messing with all this will it throw off my alignment at all? ... I removed them from the transmission because I was putting in a new clutch kit (bad clutch release bearing).
Sep 15, 2008 at 2:44 PM
KHLOW2008
  • 41,812 POSTS
Hi jeoku,
"Do I just need to put it in a vice and hammer at it? "
Yes, that is what you need to do but DO NOT hammer too hard. The CV joint is locked with the aid of a spring clip so it is best if you can get someone to pull at the CV joint to get the spring clip slightly compressed while you use a rod and hammer to punch the joint off.
Sep 18, 2008 at 7:12 AM
