[quote:488cae7132="gabriel oliveras"]Other Category problem
1997 Honda Civic 4 cyl Front Wheel Drive Manual 169400 miles
how to replace cv half shaft[/quote:488cae7132]
remove tire
remove and set aside brake caliper
remove axel nut
remove strut lower bolt and nut
remove lower ball joint bolts or nut
seperate ball joint out of the hub pull hub away from axel and set aside
remove axel
Jan 1, 2008 at 12:43 PM
