1997 Honda Civic Dragging-like noise
91,323 MILES • 4 CYL • 2WD • AUTOMATIC
STEVELOW1
  • 7 POSTS
When decelerating from around 40 MPH the car makes a dragging "shushing" sound. FYI, the axle boots were both replaced at 80,000.
Mar 24, 2009 at 3:01 AM
F4I_GUY
  • 3,302 POSTS
It sounds like your brakes are dragging.
If this is coming from the front ensure that you do not have a seized caliper or caliper pins.
If it is coming from the rear ensure that the parking brake adjustment is good and that the rear brakes are adjusted PROPERLY. A quick test would be to see how many clicks it takes to lock your parking brake. 5-7clicks is acceptable, anything lower and the rear brakes are rubbing.
This noise also may be caused by a worn out brake pad. So give your brakes a good look over!
Mar 24, 2009 at 10:13 AM
