1997 Honda Civic right axle shaft
140,599 MILES • 4 CYL • FWD • MANUAL
MARK RUSS
how do i replace. do i need any special tools?
Jan 8, 2009 at 1:07 AM
F4I_GUY
  • 3,302 POSTS
remove 32mm axle nut. use a punch and hammer to free the axle in the hub splines. Remove the lower balljoint cotter pin and the 17mm nut. use a pickle fork to crack the balljoint free of the lower control arm. remove the strut fork via 14mm pinch bolt and a 17mm nut and bolt. Pull the knuckle forward and push the axle out of the splines of the knuckle so its free to be pulled out. Get a pry bar and pry on the inner CV against the transmission and the axle should pop out along with a tiny bit of transmission fluid (so top up).
goodluck
Jan 10, 2009 at 4:56 PM
