1997 Honda Civic Civic will not start
PRNROXHRD
  • 1997 HONDA CIVIC
Engine Performance problem
1997 Honda Civic 4 cyl Front Wheel Drive 185000 miles
lately I have trouble getting my 97 civic to start back up after i've turned it off. It cranks but will not start. I have to let it sit for a while before it'll start. The only thing that has been done to it lately was a radiator replacement and I replaced a lost radiator cap. Do you have any ideas?
Tuesday, February 3rd, 2009 AT 1:02 PM
KHLOW2008
  • 41,814 POSTS
Hi prnroxhrd,
Do you have any overheating or coolant losses problem?
You need to verify what is missing causing the difficult starting and the following links have videos on how to check. Let me know what is missing and we can continue with further trouble shooting.
http://www.2carpros.com/kpages/first_things.htm
Friday, February 13th, 2009 AT 12:00 PM
PRNROXHRD
In responce to your question on weather I have coolent loss or not, I checked my radiator and there's coolent there but my resvior seems to empty out sooner than I think it should, and when I start the car, the temperature gauge reaches the normal halfway mark faster than it should but it really doesnt over heat. I also notice that the radiator fan only kicks on for about a minute when it turns on. I checked for leaks and found none. The problem did origanally start when I changed the radiator about a month ago. Also it didnt come with a radiator cap so I got another one that happened to fit but I dont think it was the one for a 97' civic. Any ideas?
Friday, February 13th, 2009 AT 11:06 PM
KHLOW2008
  • 41,814 POSTS
The reserve tank should not be depleting and when it does, it means there is a leakage somewhere and if the leak is minimal, visual inspecton might not show anything. Look out for coolant contaminations at hoses joints etc. You would need to do a pressure test if there is no visual leaks.
The radiator cap should have a rating of 1.1 bar ( 14 - 16 psi)
Did you check out the links for what is missing causing the difficult starting? Is it a fuel or ignition sparks problem?
Saturday, February 14th, 2009 AT 7:32 AM
