1997 Honda Civic CAR CUTS OFF
MP82
  • 1997 HONDA CIVIC
  • 4 CYL
  • FWD
  • 135,244 MILES
First off, the car would start but would just cut off. I notice a battery light, and saw it was the wrong battery in the car. So, I replaced the alternator and the battery. Car started right up, but then cut off again. Then I checked the main relay, it was bad, so I replaced it too. Car atarted up again but cut off again. I've check all the fuses everything checked out ok. Now the car doesn't start, just turns over, no sparks, I've rebuilt the distributor and still no sparks, but I've had tested the distributor in another car, work just fine. I also checked the computer it was fine, I mean I check timing, tried a new crank angle sensor, did a compression test 130 across, still no spark, now I think its the ignition switch. So any advice would help, thanks
Tuesday, January 22nd, 2008 AT 12:48 PM
MP82
I figure it out, it was the ignition switch as I supsect it.
Wednesday, January 23rd, 2008 AT 6:56 AM
2CARPRO JACK
  • 11,533 POSTS
Good find
Wednesday, January 23rd, 2008 AT 7:53 AM
