1996 Honda Civic fuse locations
1996 HONDA CIVIC
MAINEVEGA
Electrical problem
1996 Honda Civic 4 cyl Front Wheel Drive Manual 166k miles
I have recently lost power to my lighter (power) outlet, and to my rear window defogger. I have replaced fuses under the hood and under the dash. (not fun to reach!) with no luck. Is there an inline fuse i don't know about? I was powering a small compressor with the lighter socket, when both stopped working , so I figured it was a fuse.
any thoughts?
also power windows all work intermittantly... Wet?
frozen? Maine!
thanks for your time. Elizabeth
Feb 12, 2009 at 8:47 AM
F4I_GUY
  • 3,302 POSTS
Your ciggarette lighter fuse is located in the passenger compartment fusebox. What I would do is check all the fuses with a test light, multimeter, fuse tester, etc. to ensure all the circuits are functioning properly. Make sure you replace the fuse with the proper amperage fuse as well.
Feb 12, 2009 at 12:32 PM
