1996 Honda Civic CV joints
JUANRIVAS187
  • 1996 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 240,000 MILES
How do I change a left c v joint
Sunday, October 5th, 2008 AT 2:19 PM
BRUCE HUNT
  • 3,754 POSTS
In simple terms. You need to properly and safely raise and support the vehicle. Take off the front tire and remove the center nut on the axle. Take the brake caliper off and wire it up to get it out of the way. Remove the castle nut at the joint below the axle. Using a pry bar seperate the joint you just took the nut off. Swing the wheel assembly out of the way and slide it off the axle. Carefully pry off the cv axle from the tranny and remove. Reverse to install the new one ensuring that the cv is fully engaged in to the tranny.
Good investment is to get a service manual for the vehicle.
Monday, October 6th, 2008 AT 11:13 AM
