Engine wont start, but cranks?
DOPEDRAGONZ
  • 1996 HONDA CIVIC
  • 4 CYL
  • FWD
  • 250,000 MILES
Ok I have a 96 honda civic dx with the 1.6 sohc/non-vtec. I understand you need compression, fuel, and spark for your car to run. I was on my way somewhere a few days ago and my car felt like it was hesitating twice(kind of jerking) on the way there. When I got there I turned it off and thought nothing else of it. The next morning I tried to start it and it cranked, but wouldnt turn over and start. So I started looking around the engine bay for anything noticeable and the only thing I saw wrong was my exhaust manifold was split in half. So I took it off(in 2 pieces). I bought an aftermarket header and put it on. Of course the car still wouldnt start. I bought an obd 2 tester and the codes it threw were, 2 misfires and a problem with the catalytic convertor. So I got rid of the cat all together since I had just put a new header on anyway. I did a compression test and it was fine. The engine is still getting fuel at the fuel rail and it is still getting spark. The spark plugs were black from carbon though and were brand new. Earlier a friend helped out and adjusted the timing a few times and tried to start it, but it still wouldnt start even though it sounded like it would. Instead it just backfired loudly and blew out black smoke. I also changed the fuel filter(forgot to mention that). I have spoken to a few friends that are mechanics and the only thing anybody has guessed is a sensor or possibly the injectors even though that doesnt make sense to me. Well I guess thats all I can say so any help would be greatly appreciated. Thanks
Sunday, April 27th, 2008 AT 9:58 PM
To me it sounds like the timing belt let go here is a guide to help you check it out.
https://www.2carpros.com/diagrams/honda/civic/1996
The fuel might be making it all the way to the fuel rail but is the injector/s opening and closing as programmed and also is it the correct fuel pressure. If its getting fuel in the combustion chamber-I recommend you recheck the valve and ignition timing once the belt is done.
Monday, April 28th, 2008 AT 3:11 AM
DOPEDRAGONZ
You nailed it the timing belt was shredded! Engine runs great. Thanks for your help this site is great :)
Monday, April 28th, 2008 AT 3:30 AM
