This transmission works well until you drive it a short distance (1-2 miles or so) then it begins to slip or disengage the drive (all gears). You can shut it off and start it up and it again works well immediately for another short distance. Let it sit a short while and it will work again for the above distance and repeat. Once in an irregular and infrequent while there is some torque converter shutter. This problem began following the replacement of both CV axles. Thank you.
Jul 12, 2009 at 4:26 PM
