Transmission problem
2002 HONDA CIVIC
175,000 MILES • 1.7L • 4 CYL • FWD • AUTOMATIC
SAMGREW
  • 59 POSTS
Getting code P0740 Torque Converter Clutch Silenoid Ciruit.
What is the problem and an I fix it myself. Reaches very high RPM before shifting.
May 4, 2016 at 8:11 AM
HMAC300
  • 48,601 POSTS
this can be the solenoids in trans are no good or the trans needs a rebuild. check fluid level and for color if dark brown or black it will need a rebuild more than likely.you'll have to find out which trans you have as there are 4 different ones. but a trans guy will know and give a better opinion.
May 4, 2016 at 8:41 AM
