1995 Honda Civic restriction in the system
SDESISLETS1
Air Conditioning problem
1995 Honda Civic Two Wheel Drive Manual
I believe I have a restriction somewhere in my system. What components do I need to look at, how do I find out where it is, and how do I repair it?
Jul 13, 2009 at 11:27 AM
  • 31,937 POSTS
HI there,
You should first get a air con tech to check the system pressures as this will give a good indication as to where any problem may lie, start here.
mark (mhpautos)
Jul 13, 2009 at 4:23 PM
TED-E-DEE
  • 109 POSTS
HAVE SOMEONE TURN A/C ON WHILE YOU WATCH FINS ON A/C COMPRESSOR. Do they start spin'n when a/c on ? If they do, you know there is enough freon to turn system on. Ck. Hot/Cold valve near Firewall, it's inside heter hose. Disconnect cable & make sure this valve is working freely. Spray w/penatrant if needed & work back & forth to free it up. Reconnect cable. If you suspect no freon, depress shrader valve {looks like tire valve} & see if anything comes out. DON'T 4GET SAFETY GLASSES ! Please b carefull depressing valve. There is one on large hose, & one on small hose. Good Luck.
Jul 13, 2009 at 8:55 PM
