HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Overheat
SPONSORED LINKS
1995 Honda Civic Engine keeps overheatin
ROBBYD2070
MEMBER
1995 HONDA CIVIC
Engine Cooling problem
1995 Honda Civic 4 cyl Two Wheel Drive 186000 miles
My 1995 Honda Civic keeps overheating. This is after the heads were replaced on the vehicle. WHat is happening?
Thursday, September 4th, 2008 AT 5:58 PM
KHLOW2008
MECHANIC
Hi robbyd2070,
Overheating are caused by the following
1. Lack of coolant.
2. Weak water pump.
3. Clogged radiator or coolant passages, (stuck thermostat etc.
4. Faulty cooling fans.
Did you check all the above?
SPONSORED LINKS
Monday, September 8th, 2008 AT 10:24 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Engine Overheating
Four Cylinder Two Wheel Drive Automatic 150,000 Miles. I Bought A 1995 Honda Civic, Drove It About 15 Miles And It Overheated. I Went To...
Asked by
tss31
1995
HONDA CIVIC
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1995 Honda Civic Engine Smokeing Out Tailpipe
Engine Smokeing White Smoke Out Tail Pipe, No Coolant Loss ;oil Dipstick Smokeing When Car Gets Hot, Car Does Not Overheat.
Asked by
Whenpigsfkybg
1995
HONDA CIVIC
Why Does My Car Overheat After Getting Off The Freeway
Recently, About A Month Ago I Replaced The Radiator In My Civic Because The Radiator Had A Hole That Had Started To Spew Coolant. Other...
Asked by
kickjon1985
1 IMAGE
1998
HONDA CIVIC
Engine Overheating
Issue: Overheating. I Have Had This Problem For Around 2.5 Years. I'm Not Sure What Could Have Caused The Problem - One Day While...
Asked by
ts87
2000
HONDA CIVIC
Engine Overheating
Four Cylinder Front Wheel Drive Automatic 116,000 Miles. I Have Been Having Overheating Issues With My Car For The Past Six Months And...
Asked by
babylegs81
3 IMAGES
2005
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
