1994 Honda Civic repair tie rod end boots
JACKTORES69
  • 1994 HONDA CIVIC
Tires and Wheels problem
1994 Honda Civic 4 cyl Front Wheel Drive Automatic
I need directions on how to replace tie end boots, thanks.
Thursday, March 26th, 2009 AT 5:29 PM
F4I_GUY
  • 3,302 POSTS
I am unsure if you can purchase just the grease boots, but if you have them this is what you need to do.
Remove the cotter pin, remove 17mm castle nut. Hit the knuckle with a hammer until the tie rod end comes loose and you can lift it out of the knuckle. Remove the boot and install in reverse order.
Thursday, March 26th, 2009 AT 6:02 PM
