1994 Honda Civic oil in cylinders
210,000 MILES • 4 CYL • FWD • MANUAL
COOLBAUGH2008
ok so i replaced all gaskets on top end of engine and got the timeing set while adjusting the timeing i pulled my plugs and noticed i have oil in two of my cylinders what could cause this im hopeing i don't have to tear it back apart and change the piston rings but if thats the case do i need to do anything else or can i just replace the rings and if for some reason i added to much oil could this cause the problem
Mar 26, 2009 at 2:03 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d75c17e908="coolbaugh2008"]Engine Mechanical problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual 210000 miles
ok so i replaced all gaskets on top end of engine and got the timeing set while adjusting the timeing i pulled my plugs and noticed i have oil in two of my cylinders what could cause this im hopeing i don't have to tear it back apart and change the piston rings but if thats the case do i need to do anything else or can i just replace the rings and if for some reason i added to much oil could this cause the problem[/quote:d75c17e908]
First thing I would do is a compression check. If compression is low and there is oil in the cylinder then there is a good possiblilty that the Head Gasket is misaligned or was damaged during installation.
Mar 26, 2009 at 2:09 PM
