HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Revs Up
1993 Honda Civic engine revs
AREATHAJ
MEMBER
1993 HONDA CIVIC
4 CYL
FWD
AUTOMATIC
117 MILES
Engine revs up and down while in park
Wednesday, December 9th, 2009 AT 10:18 PM
KHLOW2008
MECHANIC
Hi areathaj,
When surging occurs, check for :
1. Leaking vacumns.
2. Improperly adjusted idling speed.
3. Faulty fast idle thermo valve ( FITV).
4. Low coolant level or clogged coolant hoses to EACV and FITV.
SPONSORED LINKS
Thursday, December 10th, 2009 AT 6:13 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
If My Engine Revs Instead Of Accelerating How Costly...
I Drive An Old 1993 Honda Civic, This Afternoon, When Ever I Press The Accelerator, The Engin Revs Up And There Is No More Drive. I Would...
Asked by
Nikko
1993
HONDA CIVIC
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1993 Honda Civic Idles 2000 Rpms
Iac Valve Ok Thermo Valve Ok Ignition Timming Dead On Ecu Chipped Reburned New Chip No Vac Leaks Even Replaced All Vac Hoses And Check...
Asked by
chris93civic
1993
HONDA CIVIC
Engine Problem
I Have A 1993 Honda Civic Lx Carburetor Type, My Problem Is When I Hit The Accelerator Pedal Fast Reaching The Rpm To 3, It Seems That It...
Asked by
stormrage
1993
HONDA CIVIC
1993 Honda Civic Engine Starts But When I Gas Up...
Ok The Title Is Kinda Blurry So Here It Goes My Car Starts Fine, Then I Went To The Gas Station To Gas Up, Obviously I Need To Turn The...
Asked by
Chiekotz
1 ANSWER
1993
HONDA CIVIC
1993 Honda Civic
Engine Performance Problem 1993 Honda Civic Front Wheel Drive Manual 255378 Miles How Do I Clean Out My Idle Control Switch To Keep My...
Asked by
FloodedDoomsday
1 ANSWER
1993
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Vacuum Leak
Online car repair manuals
