Read Codes?
DOCHAGERTY
  • 9,603 POSTS
Tell us the meaning of code 9 please
Tuesday, October 24th, 2017 AT 11:47 AM (Merged)
K3N3T1K_K
  • 8 POSTS
Code 9 - CYP Sensor (Distributor Assembly) it's inside the Distributor.
K3N3T1K_K
  • 8 POSTS
CYP - Cylinder Position Sensor
  • 110,055 POSTS
It could be a number of things. Since you already replaced the distributor and the problem exists, check the following:
Distributor cap
Rotor
Ignition wires (make sure there are no electrical leaks) easiest to do in the dark.
With a timing light, check ignition timing to make sure it is correct and didn't jump time
If everything checks okay, it sounds like the CYP sensor is bad even in the new part.
Let me know what you find.
