1992 Honda Civic low oil pressure when warm
1992 HONDA CIVIC
JOSHUA1234
Noises problem
1992 Honda Civic 4 cyl Front Wheel Drive Manual 100 km miles
hi i have a 1992 honda civic 1.6l brand new engine.when it warms up the oil pressure wont go over 20psi,when its cold its at 80 psi,when i flutter the gas it sounds like a bunch of marbles.at idle it sounds fine.and at 3000rpm it sounds fine.it only does it when i flutter the gas or take of just wondering what it might be thanks
Aug 24, 2008 at 7:24 PM
Check the oil pressure with a mechanical gauge-if normal replace the oil pressure sending unit-abnormal-could mean engine bearings/oil pump/clogged pick-up screen/sludge etc.
Could be the EGR valve not opening and causing the engine to detonate/ping-does it sound like -when you throw in a bunch of marbles in an empty can?
Aug 24, 2008 at 8:16 PM
JOSHUA1234
it sounds like a connecting rod going bad i have mechanical gage its 80 psi when it warms up and 20 when its war a 3000 rpm and 0 at idle no egr on thi motor
Aug 25, 2008 at 5:14 AM
Idle the engine and start removing plug wires one at time the one that lessen the noise is the trouble area
Aug 25, 2008 at 6:50 AM
JOSHUA1234
the dosen t make any noise at idle the compression is right up no oveer heating just not much oil pressure when the car is warm
Aug 25, 2008 at 8:49 AM
How did you get this psi?
Aug 25, 2008 at 9:38 AM
